'37 B starting
flooding question
JAE-Tx
07-09-2001 07:17:49
Got an early B - hand crank - and when I first start her, if I turn on the gas first she floods.
Seems to start her I have to crank it with the gas shut off, and no choke. Once she hits, I can turn on the gas and all's well.
Carburetor is rebuilt, and the problem continues - she floods instantly.
Any suggestions? Thanks for the help.
John Johnson
02-26-2002 10:15:49
 Re: '37 B starting - flooding question in reply to JAE-Tx, 07-09-2001 07:17:49
What is the largest flood in the world
Tyler(WA)
07-09-2001 09:13:51
Had the same problem with a freshly rebuilt "B" carb. The float was set too high. After I re-adjusted the float setting, all was well.
Maybe that's your problem too.
steve
07-09-2001 18:06:32
 Re: Re: '37 B starting - flooding question in reply to Tyler(WA), 07-09-2001 09:13:51
if not the float, then the needle vavle that it pushes closed to shut off the fuel has a crack in the seat.
