3 Brush Generators
S.AMMER
07-12-2001 17:47:09
Can anyone out there please tell me how to test a 3 brush generator from a 1948 Allis chalmers C, it seem as testing generators is a lost art. Thank you in advance.
steve
07-12-2001 20:11:04
 Re: 3 Brush Generators in reply to S.AMMER, 07-12-2001 17:47:09
leave your e-mail address
S.AMMER
07-13-2001 12:12:22
 Re: Re: 3 Brush Generators in reply to steve, 07-12-2001 20:11:04
Thanks for the info, steve but I am mostly looking for a bench test as I am still a long ways from having the tractor running but would like the print as I have lost mine. thanks again
steve
07-12-2001 20:08:57
there are two main terminals on th generator "F" and "A". The F is the field terminal and is wired thru the headlight switch resistor to ground. Basically to test you can connect a wire from "F" to the tractor frame and ground it. This should make the generator go to "wide open" or 10 amp charge. The "A" terminal goes to the cutout relay, what some people call the voltage regulator. It connects to the "G" (generator) terminal of the relay. The other cutout terminal is the "B" or battery terminal. THe "B" terminal has a wire that goes to the amp meter and then the battery. 1. ground the F terminal 2. with the tractor running, open and close the cutout terminals with a small stick. 3.look for movement in the amp meter. 4. if all wires are connected, the cutout points are not burnt, you should see ampmeter move. if not the generator is probably toast. 5. one good test with a volt meter is to see if you have voltage at the "A" terminal with the engine off when you open and close the cutout relay. the battery should go thru the ampmeter thru the relay to the A terminal if all wires are good. Remember the tractor is positive ground. the negative terminal goes to the ampmeter, unless the tractor has been converted. I will e-mail you a print of wiring. It is not uncommon for the light switch to go bad, or loose its ground. Grounding the F terminal on generator will tell you that.
