6080 power steering
Eric D
01-13-1999 16:48:48
We run in north east Nebraska. Usually it is when we start for the first time of the day, or if it sits for a few hours. Now when we have it pluged in so it will start easier, it usually works fine.
Gordon Chance
01-13-1999 19:54:19
 Re: 6080 power steering in reply to Eric D, 01-13-1999 16:48:48
Eric D: If you haven't already done this I would reccomend that you change your hydraulic filters. Depending on the age of your tractor, you could have one or two filters located under the platform on the left side. If you haven't changed your hydraulic oil recently it would be a good idea to do so. Also check any hoses and connections on the suction line for tightness and possible air leaks. If the pump is in good shape this should solve your problem. If the problem is still there after doing these things then the pump is worn and will need new wear plates and a new shaft seal. I hope that this information helps you to solve your problem. Gordon
