CA hyd. problems
Alan
07-19-2001 16:30:51
Have been working on a CA.Got it put back together and running.BUT,cannot get any hyd function. Got a rebuilt pump and put it on.Still no good.Any ideas? Thanks,Alan
big fred
07-20-2001 14:38:31
 Re: CA hyd. problems in reply to Alan, 07-19-2001 16:30:51
Don't know if this is applicable to the CA or not, but on my IH 300U I lost hydraulic pressure and figured it wasn't pulling fluid from the reservoir since the line to the pump was long and full of air. I took off the reservoir vent filter and blew LOW PRESSURE air, about 5 psi, into the reservoir with the engine running. In a couple seconds the pump loaded up and I had good pressure. It is very important to keep the pressure very low, though, since the reservoir is not meant to take pressure.
KURT
07-20-2001 12:34:49
First check the oil level, check to see if fluid will come out of the pump and see if pump shaft is turning.
