52 Model C
Alan Baldwin
07-21-2001 15:13:59
I am having trouble with my little C it runs great and then it starts to blow water out of the over flow tube on the radiator after it runs for about 10 minutes and the oil has some water in it any ideas? Thanks in advance for any help with this problem. Alan
Phil Auten (Tx)
07-22-2001 09:48:57
 Re: 52 Model C in reply to Alan Baldwin, 07-21-2001 15:13:59
Alan,
Most likely the head gasket is blown. Just be sure to check the head and block mating surfaces for flatness before reassembling. As for the cracks between cylinders in the block, as long as the surface is not distorted, a new gasket should seal it. Since this gasket leaks, you might want to also consider new head bolts. The ones you have now may be stretched and not holding torque (check the torque on the bolts before pulling the head to find the bad bolt/s).
Phil
Alan Baldwin
07-22-2001 08:26:40
Thanks guys im going to pull the head and see what I can find.
Duey (IA)
07-21-2001 18:12:50
Alan,
My guess is a blown head gasket. Compression leaking into the water jacket and water leaking into the pushrod galley then into the pan. Duey
steve
07-21-2001 20:15:18
 Re: Re: 52 Model C in reply to Duey (IA), 07-21-2001 18:12:50
Agree- head gasket, and check the block top surface for crack.
Duey (IA)
07-21-2001 18:10:21
Alan,
