AC 190 value
doug
08-02-2001 14:20:28
A buddy of mine has a 190XT with a cab, do not know the year, that he is wanting to sell. It is generally in good shape, could use seat & paint, but it has a leak of anti-freeze into the oil system. He asked me if I knew what the tractor was worth with this type of engine problem. I told him I could ask around. Back tires are fair, fronts need replaced but do hold air.
Any input on the value of this tractor?
Thanks in advance,
Doug
lonn
08-06-2001 17:04:09
 Re: AC 190 value in reply to doug, 08-02-2001 14:20:28
Not much with coolant getting into the oil. That will cause a complete engine failure and the only warning is usually when you see the coolant. It could blow at any time. Most likely need sleeves and pistons and probably machine work to the block to repair.
