Allis Pulling
al
08-16-2001 08:19:12
I have a 1943 allis chalmers c that i pull with how can i get better traction. i have 11/2/24 tires. Thanks
Nick(OH)
08-16-2001 15:16:44
 Re: Allis Pulling in reply to al, 08-16-2001 08:19:12
I pull a 1941 C with Titan 11.2-24 tires in the 3,000 pound class. For better traction you can add wheel weights or if the rules let you, use hang on weights so you can move the weight around. If your front comes up to high you will lose traction. You could also try changing the tire air pressure. I pull with around 8 to 10 pounds. Dick L also pulls a 41 C so he might have some more info for you.
