7050 crankshaft
j moon
08-22-2001 19:55:51
has any one used a crank on a 7050 that has been turned,or do i have to get a new one.crankshaft failure is common.
Gary
08-27-2001 19:31:39
 Re: 7050 crankshaft in reply to j moon, 08-22-2001 19:55:51
I have overhauled several 3700 series engines and have had cranks ground. I would't use the crank if ground past.020. New brg cap bolts can be bought at a agco/allis dealer.
John
08-23-2001 11:15:45
The crank on the 3500/3700 engines can be ground and shot peened again without too much fear. The problem crank is in the smaller engine, 301cid. As long as your not turning over 160 hp have the crank redone.
Jack Cobb
08-26-2001 18:48:41
 Re: Re: 7050 crankshaft in reply to John, 08-23-2001 11:15:45
Wow, I'd never do that. The 426 has a knack of grenading, and I thought grinding the crank was a no no! Plus, use the new bearing cap bolts while your in there!
Craig Preston
08-27-2001 10:46:52
 Re: Re: Re: 7050 crankshaft in reply to Jack Cobb, 08-26-2001 18:48:41
How do you get the new bearing cap bolts? Are the y available from my Allis dealer?
