Wheel weights
'Bandit
08-30-2001 07:15:55
I have 2 wheel weights that fit an Allis model C. I figure they weigh about 50 pounds each. Would they be worth selling? How much would the bring?
They bolt on the outside of the hub.
Chris
08-30-2001 08:57:30
 Re: wheel weights in reply to 'Bandit, 08-30-2001 07:15:55
Where are you located?
'Bandit'
08-30-2001 09:03:25
 Re: Re: wheel weights in reply to Chris, 08-30-2001 08:57:30
Western Pennsylvania
Paul
08-31-2001 09:54:24
 Re: Re: Re: wheel weights in reply to 'Bandit', 08-30-2001 09:03:25
Factory rear wheel C weights would weigh about 150 lb. apiece, and front wheel C weights would weigh about 100 lb. apiece.
Do they have an identifying casting number? I suspect yours are not AC made even though they fit your wheels, unless they are weights from a later model tractor.
'Bandit'
08-31-2001 10:19:58
 Re: Re: Re: Re: wheel weights in reply to Paul, 08-31-2001 09:54:24
more than possiblem, there are #'s on them but i'd have to check and see what they are.
I can lift the weights by myself, so i don't think they are 150 pounds. I would guess and say they weigh between 50 and 100 pounds. Well at any rate, what would a set of weights like that sell for?
Paul
09-01-2001 17:05:19
 Re: Re: Re: Re: Re: wheel weights in reply to 'Bandit', 08-31-2001 10:19:58
Unfortunately, identification of manufacturer is crucial to valuation of weights. Casting #'s and any mfg. marks which you can find and post would be a help.
Dick L
09-01-2001 13:05:40
C weights weigh 100 lbs each and the flat B weights weigh 125 each. I have two sets of each and am looking for two more sets. Shoot me an email if you want to get rid of them. I plan on going to NJ soon by way of the Turn Pike. If your not to far from that I would stop by.
