12 volt D12 series III Where do I put the ground wire
Mark
09-10-2001 13:08:56
I just bought a D12 SN 9863 and would like to know where I put the battery leads. Is this a pos ground or negative to the ground wire?
Thanks,
Mark
steve
09-10-2001 15:18:13
 Re: 12 volt D12 series III Where do I put the ground wire in reply to Mark, 09-10-2001 13:08:56
The D series when updated from 6 volt systems (WD,B,C) were all 12 volt positive ground. The negative terminal goes to the starter or relay. The positive wire is bolted to the tractor frame. If connected backward the engine will start and run fine. The generator will fail as it is built for a positive ground system.
