AC
B Engine #
Brian
09-10-2001 15:53:44
I Have a '39 B that I am rebuilding and was wondering how to tell if the engine is origional. The # on the back left side of the block is P13604G There is also a # on the front left side of the block that # is 6-30-45 this looks like a date to me possably? That would indicate the engine is not origional. Any help appriciated.
Dick L
09-10-2001 20:18:58
 Re: AC - B Engine # in reply to Brian, 09-10-2001 15:53:44
third party image
You can tell that this block was for a 1938 by the (10) at the end of the casting number. A 1939 had a (11) at the end of this casting number.
steve
09-10-2001 19:38:37
Brian, there were 32,000 B tractors built by 1940, so a serial number of 13,000 in 1939 is right. They started with number 11,000 that year. Since no model C were built before 1940, all the engines went into the B tractor. The next problem is i thought the engine number started with BE then 13604. Are you sure it is a "P" the G at the end i believe means gasoline. Look at the tractor sealial number by the transmission shift lever. It should be real close to 13600.
