AC
C Rear Wheels and Cold Starting
Cj
09-13-2001 12:20:16
Hey all, I bought a great little AC-C (1947 C50756) . . .What a great Tractor, Having a couple of problems
Wheel Fall off Rt Rear, other wheel has 2 eccentric and 1 fixed bolt/clamp assembly holding rim to wheel assembly. This side has 2 eccentric and 2 fixed assemblies, as shown in owners manual. Do these wear, and does anyone know where I can get some(Clamps and eccentric bolts) (new or used)
Cold Starting, Haven't had winter yet, but, I purchased it with a Ford Frt end loader to move snow in winter. Had 3 inches of snow the other day, Ambient air temp about 35 F, Tractor started for a few seconds, and quit, would not start again. Any suggestions? ? ?
Thanks Chris Johnston
mark dingbaum
09-14-2001 10:59:46
 Re: AC - C Rear Wheels and Cold Starting in reply to Cj, 09-13-2001 12:20:16
Hi,
You should have 2 eccentric and 2 fixed on each wheel. My '42 C has 1 eccentric and 3 fixed on each wheel and I can feel the wheels moving around on the clamps. I posted a 'wanted' ad on the classifieds here and got a bunch of responses. Some guys want $25+ for the clamp, others might sell the clamp and bolt/nut for $5. I bought enough for 4 eccentrics on each wheel to ensure i can get them tight.
Regarding the starting, check the choke to make sure it works, make sure the float setting is correct in the carb. Sounds like a fuel problem to me. If you cannot find the problem, post a more specific question and I'm sure you'll get some good advice.
good luck,
mark
tractorschmolz
09-16-2001 20:19:01
 Re: Re: AC - C Rear Wheels and Cold Starting in reply to mark dingbaum, 09-14-2001 10:59:46
At that temp the carb may be icing up as the cold is pulled past the throttle plate. Had a model C that would that, try using a heat gun (wife,s blowdryer to warm carb before starting.
