210 pto gear
CBinMo
09-28-2001 04:49:16
Does anyone know if the 1000 rpm ,pto driven gears shaft can be removed through the bell housing and gear replaced without removing the transmission. The book shows a retaining ring for the coupling ,thats what I'm concerned about my picture is'nt real clear . thanks
CBinMo
09-28-2001 17:44:02
 Re: 210 pto gear in reply to CBinMo, 09-28-2001 04:49:16
Yes you can,I know because I just did the retaining ring is a round wire,it just keeps coupler from moving around. The only problem is not dropping the coupler into the transmission case, you just have to be careful, you do need a steering wheel type puller ,thats about all besides regular tools.
