190XT turbo I.D.
KB
10-09-2001 20:23:44
What model - size turbo was used on a 190 XT Allis?
Bruce Nelson
10-11-2001 18:45:21
 Re: 190XT turbo I.D. in reply to KB, 10-09-2001 20:23:44
Allis 190's mostly all used a TRW (Thompson) turbo. Thompson later turned into Rajay. If you get a new Thompson replacment turbo, it will be a Rajay & fit right on. The latest 190's used AirResearch turbos (and all 200's). The AirResearch will fit on a Thompson equipped 190, if you use the correct (like from a 200) oil pressure line, oil drain line, pipe from compressor to intake manifold, etc. The exhaust elbows are both the same. When the 70 series tractors were made, Allis Chalmers used both Rajay & AirResearch turbos on the same models, on the same day. This created competition with turbo manufacturers & a better position for Allis.
C.B.(MO)
10-11-2001 05:03:26
Just talked to a friend at a tractor salvage,he said the turbo off a 190 will fit my tractor it's a 210 can go over to barn and look for # on mine if you wish, let me know
C.B.(MO)
10-10-2001 18:33:33
190 turbos: my book shows ,airsearch,thompson and rajay. say searly 190,s used thompson and were replaced later by airesearch but not real clear on rajay. this book lumps180,185,190,190xt,200,7000 all together so is kinda hard to understand. hope this helped
