3 point on AC B Series
Joel Thomas
10-11-2001 21:13:57
I am considering the 3point hitch on my 1949 AC B series from C and D Equipment does anybody know about this conversion and have any advise,
the tractor has no hydraulic setup now can it be added??
thanks
Joe
10-12-2001 06:53:51
 Re: 3 point on AC B Series in reply to Joel Thomas, 10-11-2001 21:13:57
I have a C&D hitch on my JD B and it is very sturdy, well made, and works well. Putting one on an Allis B without hydraulics sounds like a lot of work and expense. If you want a small Allis, I would suggest getting a CA and going from there. It would probably be a lot more cost effective. I have a CA and it is my favorite tractor. It is very reliable and versatile and will do just about everything on a small farm that its light weight will allow. For example, it will mow and bale, but it is not large enough to pull a baler with a kicker plus a hay wagon behind. I use it to plow, disc, cultivate, mow, rake, ted, bale, and pull an allcrop 60 combine. You can't beat an Allis.
