3-point conversion
David Neff
10-21-2001 04:24:15
I was wondering if anyone had any plans for a three point conversion for a WD. I would like to build one or purchase one really resonable. I only use the tractor two to three times a year to bush hog.
Bryan Smith
11-01-2001 11:06:17
 Re: 3-point conversion in reply to David Neff, 10-21-2001 04:24:15
Try these sites:
Link
Link
Link
(already mentioned)
Dennis Reno
10-31-2001 13:09:13
I have a 3 point conversion for sale. It fits my WD45. The price is $200.00 It is a factory style
conversion, ready to use. Let me know. Dennis
Dave in Mo
10-22-2001 04:53:52
Worksaver will sell the individual components I believe and they have exploded views and parts lists online. I bought a Saginaw unit for my WD because I wanted all the geometry right. It's a VERY heavy unit set up for Category 1 and 2 implements and cost $425. The draft control is by-passed with this unit.
steve
10-21-2001 20:17:40
Link
this is a good place to look to see after market hitches. i dont know much about the specifics on the WD. I mad a three point hit for a B and a C tractors by purchasing 32 inch long lift arms for $40. each at the local farm store. I made a lower mounting frame fron 4 inch angle and mounted between the axle drop boxes. you can also use the circlular drawbar on a C. The upper arms and hydraulic cylinder actuator rod are the trick parts. If you have the lift arms off the snap coupler already mounted you are home free. if not, try to look at a WD with the smap couple upper arm setup. C&D is one one of the companies that sell hitches. There are several others.
steve
10-21-2001 20:34:52
 Re: Re: 3-point conversion in reply to steve, 10-21-2001 20:17:40
also try---- www.worksaver.com
