180 Diesel Fuel line
Matt
10-22-2001 05:09:21
The line that runs from the settlement bowl to the primer pump split or wore through on the edge of the starter. I do not know if this is high pressure line? Can I cut the ends and substitute a pice of rubber fuel line with some hose clamps? Since bending steel is pretty tough can I use 5/16" copper as a easily bendable replacement if the rubber hose idea will not work? Thanks in advance.
Joe
10-22-2001 08:24:00
 Re: 180 Diesel Fuel line in reply to Matt, 10-22-2001 05:09:21
I agree, I have a 180 as well, and replaced part of the line with a rubber fuel hose... would this get air in the system? and need to bleed the fuel line? We ran out of Diesel (not my fault, I wasnt driving it,, only had to fix it later) and had a heck of a time, because we had to bleed all the air out of the lines.. to get it to run again.
C.B.(MO)
10-22-2001 05:16:13
thats not a pressure line rubber or copper is fine. I used rubber on my two ten
