AC C Zenith carb
Tom Smith
10-26-2001 19:19:52
How do you tell which carb you have on a C. The book I have lists 2 possibilities. But there are no matching numbers or a tag on the carb that I can see. I am used to JD's and this is my first AC. Thanks for the help in advance. Tom
Jerry Coulter
10-27-2001 18:26:59
 Re: AC C Zenith carb in reply to Tom Smith, 10-26-2001 19:19:52
The parts book lists 14 different Zenith carbs and 2 Marvel-Sheblers. There is a round disc with stamped numbers riveted to the carb, facing up on the Zenith and to the side on the Marvel.
You need to find the numbers to buy correct parts.
steve
10-26-2001 20:16:31
general appearance--
---zenith bowl is more of a figure eight with throttle port at the narrow part of the 8. also has a drain screw in the bowl pointing straight forward. bottom drain screw on bowl is straight downward. arm on choke shaft that the choke rod clips to is two layers thick sheetmetal.
----marvel schebler bowl is more rounded with the throttle port in the middle.front of the bowl is smooth and rounded, no screws or ports. bottom drain i believe comes out at an angel, not straight downward, and some of them were petcocks, not plugs.
--i think i got that all right.
