5040 exhaust
wdgloff
10-28-2001 17:33:36
Using a 5040 to brush hog. Do these tractors put out a more smoke when cold? Fogs pretty good. I would say diesel, not oil smoke. Seems pretty good on fuel and power, starts ok. Changed oil, filter, and air filter. Usually sits all winter.
greg
11-15-2001 18:54:43
 Re: 5040 exhaust in reply to wdgloff, 10-28-2001 17:33:36
Most any diesel that is non-electronically managed, fuel-wise, will usually produce some amount of grayish-blue smoke due to low cylinder temp. If it seems to start and run OK, and has good power, I wouldn't fix something that wasn't broken. This assumes that the smoke dissipates after working and is warmed up. Good luck.
