190xt gas
Russell Montgom
10-29-2001 18:58:53
I need to split a 190xt gas is it just as simple as disconnecting the hoses and electrical lines unbolting the hood and unbolting the block from the transmission and clutch housing. Is there a saft to be taken apart when it is seperated. Thanks for the info thanks,Russell
C.B.(MO)
10-30-2001 17:43:31
 Re: 190xt gas in reply to Russell Montgomery, 10-29-2001 18:58:53
no theres no hidden shaft or anything like that just a normal clutch and pressure plate,the only real difference from a pickup or something is the PTO drive which is a hollow splined shaft that goes around the tranny input shaft and it splines into the pressure plate.I think I have pics in the manual can e mail if you need.good luck.
chrisnbeckybrown@missvalley.com
Bill from up north
10-30-2001 21:17:15
 Re: Re: 190xt gas in reply to C.B.(MO), 10-30-2001 17:43:31
OOPS - Sorry !! I worked on Allis when those tractors were new but its been a while --forgot about pto being turned around with input shaft.
Bill from up north
10-29-2001 20:00:00
When I split a tractor I drive blocks of wood in between the front axle and the housing (both sides) so it remains stable when the engine separates from the clutch housing. Also try to keep everything straight when you roll them apart so the pto drive doesn't jam in the flywheel hub. Don't forget about fuel line,steering, throttle,etc.-I almost always miss someting-like a bolt somewhere or a wire!!Good luck!!
