175 D
Gordon-Tn
11-16-2001 02:07:17
I have a 175 Diesel that is showing some oil & compresion in the coling system, in a hard pull it pushes out a small amount of colant each round of the motor and light gray smoke with slight miss,could this be a gasket or more like a head, there is no water in oil, D15 tractor, don,t have a lot of experience with diesel engines thanks for any help Gordon-Tn
Steve from Tn
11-17-2001 11:10:47
 Re: 175 D in reply to Gordon-Tn, 11-16-2001 02:07:17
Hi Gordon, I have a 175 D. I have replaced the head gasket twice. My bet would be on the head gasket. When you pull the head, look very closely at the head and the block. If there is a blown place, you can sometimes see it. There will be some discoloration sometimes. While you have the head off, you might want to have the head reworked at a head shop. I don't know which end of the state you live on, but there is a good head shop in Carothersville, Mo. I believe they charged me $200 to mill the head and grind the valves and seats. Good luck. Email me if I can help you.
Steve from Tn
11-17-2001 11:09:18
Hi Gordon, I have a 175 D. I have replaced the head gasket twice. My bet would be on the head gasket. When you pull the head, look very closely at the head and the block. If there is a blown place, you can sometimes see it. There will be some discoloration sometime. While you have the head off, you might want to have the head reworked at a head shop. I don't know which end of the state you live on, but there is a good head shop in Carothersville, Mo. I believe they charged me $200 to mill the head and grind the valves and seats. Good luck. Email me if I can help you.
Gordon-TN
11-24-2001 00:11:37
 Re: Re: 175 D in reply to Steve from Tn, 11-17-2001 11:09:18
Steve
thanks for the information, I was going to Email but didn,t have address. Thanks again
Gordon
