1936 WC valves
CWS
11-29-2001 19:19:30
Need valves for a 36 WC. Will the WD/WD45 valves work in the 12 stud head? Are the WD valves larger than the old WC valves? I would like to increase airflow if possible. Thanks
Butch (OH)
11-30-2001 06:58:30
 Re: 1936 WC valves in reply to CWS, 11-29-2001 19:19:30
The complete motor kits TISCO sells are for all WD and WC so the valve heads and stems must be the same diameter. The older WCs used a different type retainer and locks than the later ones and if memory serves me the spring diameters are different also, but if you switch everything the new style parts work in the older heads. The head on my son's '38 WC had the older style parts but I don't know if the head is original to the tractor.
