Allis B front axle
Al W (Tx)
12-29-2001 11:41:37
I recently aquired an Allis B with a strange front axle. Most B's have either an arched, fixed, cast iron front axle or the adjustable 'square' front axle. This one has a arched, cast iron axle with adjustments on the lower ends. It looks stock, but I've never seen another one like it. Does anyone have any ideas??? I have a picture if that will help.
Jerry
12-29-2001 16:23:19
 Re: Allis B front axle in reply to Al W (Tx), 12-29-2001 11:41:37
Al, I believe you have a tractor that was mfg. prior to 1940. A-C offered an adjustable arched axle as an option until 1940. Do you know the serial #? It is found stamped on the trans by the shifter. I am guessing your serial # is less than 33,500. If your serial # is higher then that it could be that sombody changed the front axle.
Al W (Tx)
12-30-2001 09:06:27
 Re: Re: Allis B front axle in reply to Jerry, 12-29-2001 16:23:19
You're right. Mine is Ser# B23112. I think it's a '39. I didn't know there was a differnet type of adjustable front. Thanks.
Tom
12-30-2001 06:40:41
There were two different types of adjustable axles before they finally standardized on the ones we all know.
