Allis B Ring Clearances?
Andrew
01-06-2002 04:52:11
I am about to re-ring my Allis B engine (3 3/8" bore) and realised that I don't know the official ring gap clearances. If someone could please let me know I'd appreciate it. Thanks. Sorry!
QQ What is the best way to orientate the ring gaps when I reassemble? (I usually just place each gap oppositely)
Andrew - Thanks!
01-06-2002 14:08:15
 Re: Allis B Ring Clearances? in reply to Andrew, 01-06-2002 04:52:11
Thank you for your prompt replies. It's 9.00am Monday here in Aust. so I'll be able to set them and reassemble today!
ssteve
01-06-2002 07:34:11
checking ring gap is wise. I found my rings were waaaaay to big. I had received a kit for the TISCO 3-7/16 pistons instead of the 3-3/8 stock AC pistons. Norm at Norms Toys was a lot of help in figuring it out and helping me with the return.
Dick L
01-06-2002 05:50:59
The ring gap is .007 to .014 . I start at the bottom and turn each ring gap about 30 deg. clock ways from the ring gap below. That is not in carved stone. You just must keep the compression from escaping through the ring gap from the firing chamber to the pan.
