180 gas gauge
Dean
01-14-2002 17:23:30
I have AC 180. Gas gauge does not work. When I turn on key the needle is past full. Thanks for some help.
Gordon (TN)
01-14-2002 23:25:07
 Re: 180 gas gauge in reply to Dean, 01-14-2002 17:23:30
Sounds to me like the wire coming from the tank is grounded, To check this remove the wire from the tank,turn the switch on,if you still have the same problem,take the wire off the gauge that goes to the tank with switch off,turn switch on, gauge should not move hope this helps Gordon
