AC Model B engine froze
Andrew McLallen
01-25-2002 06:21:07
I have a model b that the engine is froze. I filled the cylinders with Marvel Mystery Oil and let it sit for a while. Have tried hand crank, rocking it in high gear, and removing starter from fly wheel. Have had no luck getting it to break free. I could use some help with ideas before I open up the engine.
Andrew
01-27-2002 18:35:07
 Re: AC Model B engine froze in reply to Andrew McLallen, 01-25-2002 06:21:07
Thanks for all the input. Looks like you all agree it's time to open up the engine and see what I have, then go from there. It's worth the effort in the end though.
T.J._N.J.
01-26-2002 15:57:31
I am in the middle of an engine job on my 42 C and it was really stuck bad for about 15 years , about 7 years ago my dads buddy tried to pull it around and break it loose but it wouldnt budge so it was put back in the hedgerow for another few years.I took it apart and found that 2 push rods had bent badly by this and that one of the cylinders had filled with water and froze and broke out the side of the liner. Pull off the head and take a look it will only cost you a few gaskets. T.J.
ed
01-26-2002 10:02:42
Steve maybe you can get this stuff at a local auto parts store maybe you can,t. I have used "free all" to unstick a rusty steering wheel of a solid rusted shaft. I had tryed it on alot and this stuff realy works. It's different than the wd40 stuff. This stuff get's in there. I'm sold on the stuff. Let me know your progress I have to do a breakdown on my B for rings this spring. I hope this helps. we get the "free all" an Napa. ED
steve
01-25-2002 19:02:13
You might take off the valve cover and see if the valves can be pushed up and down. In reality if it is stuck real good, the rings are stuck to the pistons and the valves are stuck in the guides. I took one apart like that. Had to tap the pistons out of the block, break the rings off the pistons. Had to recut the grooves with a square file. The valves had to be tapped out (more than gently) with a hammer from the guides. After wire brushing the stems and honing the cylinders and sanding the pistons .001 undersize, thing looked pretty good. But i cant imagine getting it to run the way it was. I have got slightly stuck engines to run as you mention, but if it is stuck like you say, i think its too late to break loose and expect a decent running engine.
