CA question
MR. allis
02-14-2002 19:42:19
Were are all the grease fitting on the CA? What fluid is in the front tri-cycle and were do you put it in at?
Thanks in advance for your help
Thanks
RMD
02-18-2002 14:09:15
 Re: CA question in reply to MR. allis, 02-14-2002 19:42:19
There are no grease fittings on a CA. AC had the philosphy that grease fittings attacted dirt and caused more harm than good. The only place I'm not sure of would be the clutch throwout bearing which you would access from the inspection hole on the bottom of the bell housing.
