D14 lift power
BEN
03-12-2002 18:22:49
One of my neighbors has baled several 950lb bales of hay. The vermeer baler he used is built to make these small bales. The question is will my d14 with a three point lift this bale. Has anyone tried this?
steve
03-14-2002 19:35:18
 Re: d14 lift power in reply to BEN, 03-12-2002 18:22:49
Ben, you got the power, but not the weight. You would need about 300-400 pounds of weight up under the radiator, or up front, to keep it on the ground.
BEN
03-15-2002 12:21:15
 Re: Re: d14 lift power in reply to steve, 03-14-2002 19:35:18
I took the d14 over to the neighbors house the bale staber he had was about 250 pounds I hooked up and picked up the 950lb bale the front end was a little light but stayed down, I even drove it two miles home in the low side of four. thanks for you help BEN
