Need snap coupler for Allis Chalmers drill planter
Adam Davis
03-24-2002 14:33:02
I recently acquired an Allis Chalmers drill planter for free. Found it in a fence row along with a model 60 all crop and two Massey harris combines. I didn't bother with the combines though. (too far gone). Anyway the planter is the old style pin hitch for the WD. Our WD has a snap coulpler hitch and I would like to find a conversion for the planter so it will fit our WD or D17. My grandfather wants to use the planter this spring to plant some sweet corn 1-2 acres. Any help would be appreciated. Thanks Adam Davis
JMS/MN
03-24-2002 19:52:34
 Re: Need snap coupler for Allis Chalmers drill planter in reply to Adam Davis, 03-24-2002 14:33:02
You can make one out of the appropriate sized shaft- check an existing piece for dimensions, it should be about 3/4 or 1 inch diameter, bend it to match the original, and weld it to a flat bar like the original coupler.
