AC D15 Gas Used Parts
Larry Hartenste
03-27-2002 19:48:26
I need the v-belt pulley that goes on the front of
the crankshaft which drives the water pump and the
generator. It's cast iron and has a keyway and a
set screw. It also has four holes in it to connect
the hydralic pump. Please help!!!!! !!1
ACPhil
03-29-2002 11:41:01
 Re: AC D15 Gas Used Parts in reply to Larry Hartensteier, 03-27-2002 19:48:26
Try Marshall Machinery in Honesdale, Pa.. Phone is 570-729-7117. They have many parts off and can UPS is to you right away if they have it. Also try Martin's Tractor Parts, Newville, Pa.. Phone # is 717-776-7542
JMS/MN
03-28-2002 06:30:07
Check the part number for your pulley vs the same part for other D series tractors. Sounds like the one on the D17. Might make it easier to find- I'd check with salvage yards. Good luck!
