Re: Re: Re: 1942 A-C Model C
TractorMike
03-31-2002 09:49:01
Steve, What if a B has the 5 bolt pattern? Did they offer that pattern later on? Thanks, TractorMike
steve
03-31-2002 17:51:33
 Re: Re: Re: Re: 1942 A-C Model C in reply to TractorMike, 03-31-2002 09:49:01
A "B" could have a 5 bolt axle if it had an adjustable front end (I think), but it would still be the narrow (approx 60 inch) wide wheel base.
TractorMike
04-01-2002 18:43:20
 Re: Re: Re: Re: Re: 1942 A-C Model C in reply to steve, 03-31-2002 17:51:33
Steve, You must be right because my "B" has the adjustable front end and the 5 bolt pattern. Were these harder to come by? Thanks, TractorMike
Bryan Smith
04-01-2002 06:12:58
The B did have that hub option for the 40" to 68" wheel tread option (I have one). A B will be about 33" between the final drives, while a C will be about 45". Look at the steering gear as mentioned above and measure between the final drives - that shoul get you set.
