6-volt check
Sheldon
03-31-2002 20:17:22
What should a 6-volt battery voltage be if it's in good working order? My sits at 6.3V Is it due for replacment?
James (MO)
04-01-2002 20:44:02
 Re: 6-volt check in reply to Sheldon, 03-31-2002 20:17:22
Lead acid batteries typically run about 2.25 volts per cell. Thus on a 6V battery (3 cells), 2.25 x 3 = 6.75 volts for a fully charged battery. Sounds like you are in the ball park, but as the others have said, it would be good to have it load tested.
Steve in N.J.
04-01-2002 19:00:05
Sheldon,
Your battery may seem to be okay sitting and not in use showing 6.3V. The real test is when you put a load to it with a load tester. You could purchase one at an auto parts store for 6 & 12 volt battery testing, or go to a local gas station that does repair work and they could probably do a load test on it for you. A good fully charged 6V battery shouldn't drop more than 1-1.5 volts with around a 10 amp draw or so. If she starts to dump quick, the battery is probably getting weak, and eventually will need replacing. Always make sure the battery is fully charged before testing. A battery that doesn't have full reserve could give you a false reading. You wouldn't want to throw out a perfectly good battery.... Steve
acd17toy
03-31-2002 21:03:11
sheldon, the only way to know for sure if a battery is up to proper volts, and cranking amps is to have it load tested most places that sell batterys should have a load tester.
Bryan Smith
04-01-2002 06:04:42
 Re: Re: 6-volt check in reply to acd17toy, 03-31-2002 21:03:11
Typically you'll get 4 to 5 years out of a battery, with heavier-duty (higher priced ones) giving longer service - I've had a few 12 volts give me 7+ years, but they were the more expensive ones that came with the cars they were in. Heavier internal plates, etc.
A good 6 volt will show something more than 6 volts, but I'm not sure of the reading. Usually the old 6 volt generators were set up to charge the battery to 7.2 to 7.3 volts - much like a 12 volt system today charges at 14.4 volts or so. Run the tractor for a while and then check the voltage - if it's at the 6.3 volt figure you mention while running then the battery obviously won't show any more than that.
