180 diesel miss
Brian
05-09-2002 01:24:14
Buddy of mine bought this tractor recently, which has a high rpm miss. I can load the engine, & the engine then runs fine-but without a load, it misses again. We had the inj nozzles tested and repaired at the AC dealership,still has the problem.I`m thinking pump, but is there anything we shoould look for before we take it Off?
Craig MO
05-09-2002 20:17:30
 Re: 180 diesel miss in reply to Brian , 05-09-2002 01:24:14
If the pump hasen't been rebuilt in the last 5 years it probably still has the old style govenor ring in it. Check timing and if its correct your problem is more than likely your pump especilly when it goes away under a load.
