180 gas run problem
Dean
05-18-2002 19:30:37
Help. I have 180 gas. A dealer and I have rebuilt carb twice. checked compression, is OK. Replaced plugs four times. replaced points three times. They put in a part to replace points.The run problem that I have is it does not seem to have full power, and seems to be running real rich. And gets gas in oil. Sure could use some help. Thanks Dean (KS)
Craig MO
05-20-2002 18:14:17
 Re: 180 gas run problem in reply to Dean , 05-18-2002 19:30:37
Like Terry said check the float level first it may be set too high. Check the governor linkage next its possible its out of adjustment. Don't rule out a leaky intake gasket. Your distibuter might not be advancing enough at higher rpms.
Terry R.
05-18-2002 21:31:26
Sounds like to me that it is flooding.Better check float level or possible needle and seat are leaking by.Terry.
