? AC sickle bar mower
Joel WA
05-20-2002 05:41:09
Need help identifying a snap-coupler sickle bar mower. So far I've determined that it is a twin wheel, can mow in any position. It's 6 foot. Most casting numbers begin with 803. Is that a hint? No trailing wheel. thanks Joel
RMD
05-20-2002 06:54:13
 Re: ? AC sickle bar mower in reply to Joel WA, 05-20-2002 05:41:09
If it truely is a Snap-Coupler madel (has eye to connect directly to Snap-Coupler bell), then it is a No. 7. The later twin wheel rear mount mowers (80R and 82R) had supplemental brackets that took the place of a connection directly to the Snap-Coupler bell. A No. 7 will connect to the Snap-coupler bell and lift arms just like any other Snap-Coupler implement plus there is a balancing spring braket that mounts on the right final drive.
Joel WA
05-20-2002 20:52:59
 Re: Re: ? AC sickle bar mower in reply to RMD, 05-20-2002 06:54:13
Hey thanks a lot on that. Now maybe to find some parts and a manual.
