WD Finals fluid change
Greg Soderberg
05-25-2002 07:39:47
Does one need to drop the pan on the finals on a WD to change the fluid? Is a new gasket required? Do the rear wheels and tires need to be removed?
DAve K
06-11-2002 13:17:24
 Re: WD Finals fluid change in reply to Greg Soderberg, 05-25-2002 07:39:47
AGCO has the gaskets but at about $12 each! They are just cork so buy a roll of cork gasket, punch or drill the holes and save a bunch of bucks! Spin the wheels out to remove the pans.
Dave
Tom
05-25-2002 17:55:36
Yes, you need to remove the pans. If you spin out or remove the wheels it will be a lot easier. You can use silicone for a gasket, don't need a gasket. Fill to plug when pan is back on. I have filled to plug or nearly so with pan off and carefully put it on. Saves having to fill later with funel or whatever. Level isn't important as long as it is to plug, a little more won't hurt. This is a good thing to do, a lot of people never do it and the finals can get some real bad looking oil in them as it gets to be 40 some years old or older.
Bryan Smith
05-28-2002 06:52:22
 Re: Re: WD Finals fluid change in reply to Tom, 05-25-2002 17:55:36
I bought some cork gaskets from my local AGCO dealer for my B's final drives. Hold your breath - $13 and change each! FYI. Needless to say I'm going to be Very Particular when I put them on ...!
