190 XT hydralic problems
BigMoe
06-10-2002 22:45:50
My hydralics pumps all the fluid to the back and pushes it out. It does not bring any back up to the transmition or steering or anything. Any ideas on how to fix this?
Joe Rebholz, IL
12-20-2003 13:09:18
 Re: 190 XT hydralic problems in reply to BigMoe, 06-10-2002 22:45:50
I read on the Allis forum to just connect a line between the drain of both units and let it equalize. Easier than spliting tractor.
Craig MO
06-11-2002 17:02:48
The only way for oil to get to the rear end is either through the seals on the pto shaft at the bottom or in your case through the seal on the power director. The oil in the power director is going past the sealing ring and then passing through the seal to the rear under pressure. You will have to split tractor and pull power director off then take off seal housing and replace the seal.
