'40 Wc
James
06-30-2002 16:09:59
What is the normal range for the oil pressure? also what would it be worth (roughly) if it runs and drives, but needs body work?
Richardh
07-01-2002 13:21:01
 Re: '40 Wc in reply to James , 06-30-2002 16:09:59
They never had much oil pre. 2 start with, as long as it does move a little it will b ok. But if u plan 2 work it hard u need 2 put a guage on it nake sure u do have at least 7# -2- 10# Price depends on how bad u want it I gave nothing 4 mine guy gave it 2 me and he dilivered it.
Tom
06-30-2002 18:27:57
if the needle moves you are OK. Have seen old ACs run when the gage showed pressure only when the oil was cold. Normal is about 12 to 15 lbs I think. You can maybe up it a little if it is much below this by putting a washer or two behind the relief/bypass valve spring.
