Ca tie rod end
Don (AR)
07-01-2002 15:00:53
I am looking for a number or type of vehicle that would have a compatable tie rod end for a ca wide front. I know I will have to weld it on but that will be no problem. Went to the parts store but there were too many to go through. Thanks for any help.
Steve in N.J.
07-01-2002 17:32:11
 Re: ca tie rod end in reply to Don (AR), 07-01-2002 15:00:53
Don,
Not sure if the CA wide front is the same as the C, but happen to have my B,IB,C,parts book close by and for the tie rod end on a C wide front, the parts book gives me P/N-211290 for the rod end, and P/N-211291 for the tube end. Requires two of each. Like I mentioned, not sure if the C & CA are the same, but you might run those numbers past Sandy Lake or Norm to see if they're correct, & whether they are available. Sandy Lake's # is 724-376-2489. Sorry, don't have Norms #. Maybe one of the other fellows could help you out with his number. Hope this helps... Steve B.
