3rd gear in a CA
Harold
07-05-2002 21:16:17
My CA Allis started jumping out of third gear once in a while, and with in 3-4 hours it was jumping out all the time. Just 3rd gear. Is that usually a fork or a bearing? and do you have to split it to get it apart? I just use it for mowing, so there is no hard pull on it. Thanks, Harold
ken
07-08-2002 13:53:00
 Re: 3rd gear in a CA in reply to Harold, 07-05-2002 21:16:17
I had a ca that did the same thing.It was the gears, they were worn off to a tapper on the side the two gears meshed on due to years of grinding them when putting in gear in a hurry and not letting them stop turning.We took the gears off and replaced them with good used ones and fixed the problem.
Trent Williams
07-07-2002 13:11:23
Gary, I fixed my 3rd gear problem on my D14. I didn't split the tractor, just some lathe and milling machine work on the shifting mechanism. I don't know if a CA has a transmission like a D14 or not. E-mail me if you want more info. Trent
