C wiring
distributor wire
Dana (IA)
07-18-2002 10:19:14
I'm just finishing converting my C back to 6 volts from 12vt. All the wiring diagrams I have located show only wiring for Mag. Can someone tell me which side of the coil (+ or -) the wire from the distributor needs to connect to? (This will in turn tell me which side I then need to connect my wire from the kill switch to)
If all goes well, my 10 month project to restore this ole girl will be done in time for a parade next weekend. I can't wait to hear it purr again!
Thanks in advance for the help!
Duey (IA)
07-18-2002 15:33:00
 Re: C wiring - distributor wire in reply to Dana (IA), 07-18-2002 10:19:14
Dana,
The - side of the amp gauge goes to the ign switch to feed 6 volt to the coil. The + side of the coil goes to the distributor. I hope the KILL switch you refer to is an ign switch. If it is a kill switch for a mag, it will be a dead short when you turn it on!! Duey
Dana (IA)
07-18-2002 17:32:30
 Re: Re: C wiring - distributor wire in reply to Duey (IA), 07-18-2002 15:33:00
Thanks Duey,
Yes, it is an ignition switch (same one that the 12 volt system used).
