WD-45 Front End Replacement
Andrew Stepania
07-22-2002 05:38:45
Anyone know if the steering box needs to be changed out when replacing a narrow front with a wide front...or are there any 'watchouts" at all, either when buying the front end or swapping it out? (I have power steering and the tractor which the wide front is coming off of does not have power steering).
Appreciate all the info that has been available on this discussion board!
JMS/MN
07-22-2002 10:10:55
 Re: WD-45 Front End Replacement in reply to Andrew Stepanian, 07-22-2002 05:38:45
Unbolt the front box- four bolts per side, knock the pin out of the u-joint, and swap front ends.
John (C-IL)
07-22-2002 07:57:37
You need the whole thing, bolster and all. You should be able to use your power steering unit with the wide front. John
