AC 190 3 point snap coupler/3-point
Kent88
08-03-2002 14:20:50
My 190 has snap coupler with a 3-point conversion kit that sways back and forth. I can't seem to get all of the slack out. The tractor serial is #2564. I was wondering if I could put later model 3-point on it?? If so what serial # did they switch to 3-point. Any help would be appreciated.
Kent88
08-05-2002 14:03:00
 Re: AC 190 3 point snap coupler/3-point in reply to Kent88, 08-03-2002 14:20:50
Thanks for the help, that should get me heading in the right direction. Kent
Okieboy
08-03-2002 19:41:26
Yes a three point of a later model will bolt on. Cylinders on the snap coupler type I believe are a little smaller. I would have to go to the shop to check the parts manual on that. Also a three point of a D19 will bolt up. Bob
chuck
08-04-2002 04:24:03
 Re: Re: AC 190 3 point snap coupler/3-point in reply to Okieboy, 08-03-2002 19:41:26
i put a 3 pth from a 190 XT on a D-19 so you should have no problem.
