1949 Model B, Rod end trouble?
Jon F.
08-08-2002 14:45:41
This is a new tractor for me. Run's very strong, no smoke, etc...
However, upon initial starting there is a slight growl in the lower end of the motor for maybe 1 or 2 seconds before the oil comes up. Looks like a simple job to drop the pan and mic the journals, but I don't know if that is really necessary. Is this typical for these old engines? Should I be concerned? Does anyone else with a B do this? ( I had an old Buick that did this for 10 years, sold to a friend and he has 10 more on it. )
DanD.
08-08-2002 15:30:02
 Re: 1949 Model B, Rod end trouble? in reply to Jon F., 08-08-2002 14:45:41
Any engine will do that until the oil pressure comes up. Also, it would be from the main bearings. The B, C, or CA does not have a drilled crankshaft and the rod bearings are lubricated by splash only...they are not fed oil under pressure.
