AC 190XT hydraulics
Ray
08-09-2002 10:10:34
I have a 190xt recently I have experinced steering problems....with it I changed the hyd filter also I got a rebuild kit for the steering ram....but for some reason it will steer pretty effertless to the left but it's hard to the right...I put gages on the hyd line to the ram and either way it's 1000 psi...also i put gages into one of the hyd ports and I can't seem to get any more the 1100 psi out of the tractor I was going to put a frontend loader on this tractor so any help would be appreciated
Ray
KEN
08-10-2002 20:33:30
 Re: AC 190XT hydraulics in reply to Ray, 08-09-2002 10:10:34
Sounds like you have a stuck valve in the hydra motor. It's under the dash at the end of the steering colunm with four hoses going to it.That is what was wrong with mine.
Ray
08-12-2002 13:15:58
 Re: Re: AC 190XT hydraulics in reply to KEN, 08-10-2002 20:33:30
ok I will try this Ken Thanks also just to compare to your problem I took the ram off of the steering linkage and tryed it it would move the ram both ways effortlessly .....
