185 Battery
Dan
09-11-2002 19:43:54
I have a 185 Diesel No Manual yet. This is my first Allis. Need to put Battery in it, there isn't one in it now. I have a few question about the battery configuration.
1.What voltage 12 or 24?
2. Pos or Neg ground? I assume neg ground.
3.Where does the ground cable attach to the frame?
It has cable from the starter to Battery compartment. But, the Cable to Frame is missing.
Thanks
Pete-mi
09-16-2002 21:09:49
 Re: 185 Battery in reply to Dan, 09-11-2002 19:43:54
If you still need a operators manual give me a email reply as I know we have a copy or two at work to sell.
DanD.
09-12-2002 12:44:31
12 volt, uses two batteries hooked in parallel configuration (one might have been standard but two would work better), negative ground like all alternater equipped machines, and I believe the ground is just hooked up to a bolt inside the battery box but I can't quite remember. Any solid connection to the tractor would work for the ground.
