Re: Re: AC-C
Bob
09-25-2002 19:18:53
Tractor Mike, I have a "C" and as you sit in the seat looking forward, the top left hole in the cap is the #1 wire. Then the firing order as previously indicated is 1-2-4-3. This is in clockwise position. So, #2 will be the one to the top right, then #4 is in the lower right and that leaves #3 in the lower left hole. (right below #1.)
Start with this and see if it helps, and if not, then something else has to be checked, but at least your firing order will be right.
