Re: Re: Re: AC-C
TractorMike
09-26-2002 16:20:46
Ok, can some one tell me what I'm doing wrong? I put the spark plug wires on the right way, and I think I timed it right. I put the (fire) mark in the center of the inspection port and I think I put the mag cap button in the right spot and the thing still don't want to start! It has a good spark. I found that out the hard way, MAN what a shock! And, Where should I put the timing mark? My shop manual says to "crank engine until NO.1 piston is on its compression stroke and flywheel timing mark is centered in inspection port located in bottom of clutch housing". Are they talking about the inspection port on the side of the clutch housing? Thanks, TractorMike
steve
09-27-2002 20:43:30
 Re: Re: Re: Re: AC-C in reply to TractorMike, 09-26-2002 16:20:46
put the TDC makr in the middle of the hole (on the left side of tractor, center of bell housing). after the tractor starts and advance kicks in, you would see the "F" mark if you have a timing light. also make sure you are at TDC on the compression stroke, and not 180 degrees off. normally you pull the no 1 plug (front) and put someones thumb on the hole while you roll motor slowly. should feel it coming up on compression, not exhaust stroke. also, is it possible you took the head off the magnito, and slide the gears back together in the wrong position?
TractorMike
09-28-2002 11:46:33
 Re: Re: Re: Re: Re: AC-C in reply to steve, 09-27-2002 20:43:30
Steve, It is possible that I put the magnito in the wrong position. I'm going to try to get things right tomorrow. I will let you know how it goes. TractorMike
