51 AC brakes??
Brian-Dexter
10-10-2002 17:35:31
I was getting my AC ready for winter and I noticed there was alot of slack in the pedal. I would like to do the brakes but I don't know were to start. How do I get to the brake pads?
Brian
JMS/MN
10-10-2002 22:51:49
 Re: 51 AC brakes?? in reply to Brian-Dexter, 10-10-2002 17:35:31
If it's a WD, remove the two covers above the differential- one is under the seat support. The bolt staring at you- needs a 3/4 inch wrench, is where you adjust the brake bands to tighten up the pedal free play. The bands are below, and you can visually check them for wear.
steve
10-11-2002 15:36:08
 Re: Re: 51 AC brakes?? in reply to JMS/MN, 10-10-2002 22:51:49
If its a smaller B or C, follow the brake rods back to the rear axle. one on each side. they connect to a cam arm thru the sheetmetal covers. behind the cam arm is a screw and lock not. loosen the nut and adjust the screw with a big screw driver. measure pedal movement
Tom
10-10-2002 18:01:52
Well what model is it?
Brian-Dexter
10-18-2002 12:51:47
 Re: Re: 51 AC brakes?? in reply to Tom, 10-10-2002 18:01:52
This is a WD model.
