How to set up weight/tires (John C IL)???
49WD
10-21-2002 15:19:11
How would you suggest i set up tires with pressure and what should i do with weight?? Get a weight bracket in front and how much to put in frnd and how much weight in rear. I have heard trial and error is the only real way to figure this out but where should i have more wieght and approx. how much weigth total???? thanks
Dave Banker
10-22-2002 05:40:59
 Re: Re: How to set up weight/tires (John C IL)??? in reply to John (C-IL), 10-21-2002 19:04:01
Gee,John guess what board this is?When I pulled I would watch other tractors ie[Allis]in my class if I did'nt know how to set weight,and try to adjust.Tires,I would set the air pressure with fully weighted tractor so all tread bars make contact,also helps if you have an adjustable draw-bar,check the rules of different clubs and organizations to see whats allowed
